Currently 12.7 but it was 13.5What voltage does the control panel say the leisure battery is at?
It doesn't change.When you press and hold the on/off in the fridge what voltage does the panel display?
I have no lights.I take it no lights come on at all when you press the on/off button
Thank you I read that thread last night. I feel when I press the button it is connecting.Same happens to me a while back, check this :https://vwcaliforniaclub.com/threads/gc-fridge-stuck-in-the-on-position.56720/post-738780
If there are no lights at all indicating either no power or an issue with the panel or electronics and you’ve checked the fuses then it’s certainly worth trying the process suggested in the thread regarding re securing the front panel button array.Thank you I read that thread last night. I feel when I press the button it is connecting.
Thank you so much for your help and time and offering to look at it. I got it sorted same problem you had. I make go and buy glue. Thanks againThank you I read that thread last night. I feel when I press the button it is connecting.
Thanks so much for your help,time and most of all the encouragement. All sorted by doing what was in the other thread.If there are no lights at all indicating either no power or an issue with the panel or electronics and you’ve checked the fuses then it’s certainly worth trying the process suggested in the thread regarding re securing the front panel button array.
