Can anyone help me find the piece number for the b-pilar trim for my VW California?
R
RiderF1
Spain
T6.1 Beach Tourer 150
Hello everyone,
I own a T6.1 VW California. I need to replace the b-pilar trim from the driver side (left). I've found a similar piece, which is 7E5867291K82V, but is not the same.
This is the one I've found:
And this is the one I need:
It would be really helpful if you can help me find the piece number.
Best regards
Hello everyone,
Best
Hi. If you can PM me the VIN number I can take a quick look...
Do you only need the little trim on the bottom of the slider? With the circle around?
Then it should be 7LA 867 034 C NA2 (where NA2 is the color code).
Without VIN number, the color code can be different. NA2 is palladium grey, bit yours looks black.
I need the whole pilar. I circled to show the difference between them
Ah, may not be able to. Might be limited to paid “vip” members? Not quite sure what to suggest since I’m not sure I’d put my vin on an open forum!!
Left B pillar for a left steering vehicle?
Must be in the trant of this: 7LA 867 291 82V (82V should be titanium black).
For the right number, you have to share your VIN number.
Or at least the model year number (a letter) and the last 6 numbers.
It should be XXXXXXXXX ? X ??????
I need all the ? .
Sorry but I can't seem to find how to DM you. I'm quite new in this forum
If you remove the piece of trim the VW Part number should be stamped/ moulded into the inside plastic surface.
Doh, very true, why didn't I think of that....?!
I need all the ? .
XXXXXXXXXLH028168
I thought it would be easier to find the piece number.
Does anyone know the right tool I have to use to remove the seat belt from the pillar trim?
The top part of the B-pillar hooks off from either the front or the back. Just be very carefull not to break the very brittle plastic.
The seatbelt is just held on by a bolt with a head of 17mm I think. Just unscrew it. When rescrewing the bolt, it has to be at 40Nm of torque.
The correct part number should be: 7LA 867 239 82V
If we are talking about the same piece.
Thank you very much for your help
I think I need a Triple Square Spline Bit Socket tool, to remove the seat belt from the pillar trim. But I'll double check to make sure.
You could be right. It is either a 17 or that one.
Like this?
