Califan61
Hi all,
I have gained access to the fuse holder under the battery this morning of my 24 ocean to check the 100a fuse and there is no big 250a fuse?? I have had the van from new and pretty sure the battery charging system has worked so im confused.
Can anyone urgently give a reason for this?I have not done any research yet as my issue was no power to the sb side of the split charge relay which I still havent resolved so was going to check the 100a fuse in there.
*Update - So figured out that 225a fuse is for the altenator but there is also no cable going to the fusebox so guess that is somewhere else on my Cali and im looking at the wrong diagrams?
Has anyone got access to newer wiring diagrams, The latest ones I have seen are 2022 and my van was built Jan/Feb 2024?
I have checked the midi fuses here and under the seat all are fine using continuity test, I think I will replace the 100a fuse as I have a spare just incase its a intermittant issue. The starter battery is getting charge from the altenator which i checked yesterday - 14.4v ish.
