2-seater bench seat cushion removal
Nykosssssssss
Nykosssssssss
Italy
I had to redo a seam on seat cushion of the rear bench on my Ocean and as I could not find any clear information online. Here you are:
  • Remove the bench drawer and the plastic cover or the smaller drawer on the side if installed.
  • Slide the seat forward so that the bench can be opened in half between seat and bed position.
  • Remove the strap on the fridge side that prevent the seat cushion to be raised.
  • Raise the seat bench and locate the two plastic clips under the that lock in place the plastic cover on the top. (With the help of a screwdriver unscrew / raise the central plastic pin so that the full clip can be removed). Circled in GREEN in the photo.
  • Lower the seat cushion in flat position and push the front plastic towards the fridge side this will unclip it. Circled in YELLOW in the photo
  • Remove the 4 screw that hold the cushion hinges in place.
