Curtis
Its great thanks Ryan works like a charm.
We got the Cali back Tuesday night last week after having the air suspension fitted. Wednesday off up to Arran for the weekend.
Very impressed with it so far. There is no way that bumps are going to be eliminated in Cali but it is definitely smoother and the harshness and crashing on rough surfaces has gone together with much less roll on corners.
Brilliant at the campsite which was wet and soggy. No messing with the ramps grovelling about and getting filthy and moving the van up and down to get it level. Pressed the auto level button on the remote and a couple of minutes later there it was, absolutely level. Each corner does it's own thing to get it spot on. After a couple of days we relevelled it as the rear of the van had sunk into the boggy ground. Again a couple of minutes and nice and level again.
On the road it maintains it's exact ride height. It's so sensitive that when we stop and one of us gets out it recognises the weight difference and compensates.
Excellent job done by Mick Leightley at SAP near Donc
Just to make sure I understand this correctly, do you end up with four presets:
Also how quickly does the height change, can you e.g. drop from motorway to parking level in a couple of seconds?
- standard (which is actually a bit lower than the factory springs based on the roof height measurements given here)
- motorway, approx 2cm lower than standard
- off road, approx 3cm higher than standard
- parking, approx 7cm lower than standard
Also where does the controller for this get located?
Thanks David
Autolevelling takes a up to a couple of minutes and is done with the ignition off. The van lowers itself and then each corner sorts itself out until it is absolutely level.
Hi, I've one more question, how does this system impact in the transmission wearing? My question is because I guess when you lift or down the Cali bearings' angle will also change.
Looks like that (good) fixed height systems based in springs used to lift also include some parts to adjust the differential height to keep the factory angle.
There are some information about that?. Thanks
I enquired about the drive shaft angles before we had it fitted as obviously these will vary with ride height.
Basically if in off road mode you are should do no more than 20mph so less stress on the drive shaft components.
The angles apparently remain within VW specified tolerances at all times as well which is one reason the system is approved by VW.
The rear diff isn't touched at all by this system. If the diff was made to go up and down then the propshaft universal joint angles would vary which I guess is not allowed for in the design unlike the driveshafts which have CV joints allowing for greater varying angles.
When the system is fitted you can specify what ride height you want. We had ours set at the standard height which the system maintains regardless of loading so in theory you should get less wear on the drive shafts than standard spring suspension. I suppose that in this respect when you lower the van it's better than having a permanently lowered setup with springs.
Briwy said it!
• The lift kit may shorten the expected service life of the drive shafts!
Question for the VB Air suspension owners.
One of the disadvantages of Calli with current standard suspension, when children sleep in the pop top and we sleep downstairs, is that when one child turns around in his bed during the night (can't teach them to do that gently and nicely), the entire car sort of bounces. It's so bad that me and my wife sometimes wake up from this.
Could we, with VB Air suspension improve this behavior? I guess when the car is in the lowest setting, the car wouldn't bounce as much, correct? But in auto level... how high does it go: from the lowest setting to as high as it needs to level the car, or from a standard/normal setting and then adjusting opposing sides?
If VB Air Suspension can improve our sleeping experience, it would help justifying the 5K eur investment a little more.
Why not use 2 x cheap scissor or bottle jacks , 1 each side under a jacking point. Thats what some Motorhome owners use to minimise this problem. Cheaper than Air SuspensionQuestion for the VB Air suspension owners.
Yes, but £20 v £5000 for Air Suspension focuses the mind.Great idea. Why didn't I think of this myself.
Cali already has one jack, just need to buy a second one. Only disadvantage is that It takes space.
