R_Sargeant_CH
I know what is it.Prob gotta be over 60 to know what it is![]()
I’ve had one a couple of months. It does produce a good shot - on the other hand it’s quite finicky and needs a good, consistent grinder to get the best out of it. Not hard to grind a smidge too fine and end up choking it. Everything has to be properly pre heated or you end up with a lukewarm shot. You’ll need a small scale to get the dose right too (or pre weigh all the doses into ziplock bags!).I need an espresso in the morning. This on my to-buy list
View attachment 91591View attachment 91590
I bought a 1Zpresso grinder too. The one with the Italmill burrs. Currently my go to for drop coffee at home as my Londinium espresso maker is still in storage. I bought the grinder primarily for camper van duties, but it works so well I use it all the time.I’ve had one a couple of months. It does produce a good shot - on the other hand it’s quite finicky and needs a good, consistent grinder to get the best out of it. Not hard to grind a smidge too fine and end up choking it. Everything has to be properly pre heated or you end up with a lukewarm shot. You’ll need a small scale to get the dose right too (or pre weigh all the doses into ziplock bags!).
My van camping setup is the Picopresso and a 1Zpresso hand grinder. 1kg beans from Syra in Barcelona. If moto camping, it’s an aeropress and a smaller grinder that fits inside it.
I don’t remember which model mine is, but is geared towards the finer grinds. I should try it with my home machine! It does suffer a bit from retention around the burrsI bought a 1Zpresso grinder too. The one with the Italmill burrs. Currently my go to for drop coffee at home as my Londinium espresso maker is still in storage. I bought the grinder primarily for camper van duties, but it works so well I use it all the time.
I can vouch for the 1ZPRESSO grinders, not cheap but worth the mone.plus
= Coffee Nirvana![]()
Agreed. The engineering is second to none and trounces the Comandante on price. The one I have as the Italian made Italmill conical burr set. I use it even at home its so good. Only downside is switching from pour over to espresso. The settings aren't intuitive and 1 or 2 clicks can make a noticeable difference. I keep it dialed in for espresso.I can vouch for the 1ZPRESSO grinders, not cheap but worth the mone.
This topic can get lively, personally I like all manual devices and a longer cup:Hello folks, has anyone had any recent success with a decent compact coffee machine for the camper?
same for usMoka pot for us![]()
Every time! Aeropress is groovy but doesn’t make the coffee strong enough for me
We’re gonna need more detail - espresso, milk based drinks, pour over, filter, immersion, siphon, Greek/Turkish, Vietnamese. I can only cater for 6 of these in my van but I’m working on it… ;-)Hello folks, has anyone had any recent success with a decent compact coffee machine for the camper?
Call me a pedant, but surely you are slowly heading in my direction?If we’re playing top trumpsView attachment 143847Call me a pedant, but surely you are slowly heading in my direction?
Rocket Porta Via with filtered water, I’ve not found an equivalent grinder so have to prepare earlier, I guess I could take the Kruve filters to try and get a consistent grind size from a portable grinder in a pinch.
I am only half joking - I don’t use it in the van very often but have been known to take it to festivals when I’m playing top trumps with my friends on who has the most Gucci camping set up.
