G
Gavin UB
- Messages
- 21
- Vehicle
- T6 Ocean 204 4Motion
First of all I just want to say what a fantastic resource this forum and its members are and have been throughout our 9 and a half years ownership. I have posted very little as we don’t normally use any social media. In all that time I have never failed to find the answer to any problem, until now!
Our vehicle has developed a significant rattle and vibration that emanates from behind the air vents on the rear near side beside the C pillar. The rattle occurs on any surface that is not perfectly smooth and the rattle / resonance occurs when engine rpm is approaching 1400, especially under torque.
I am pretty certain that I have eliminated all usual causes and have had an independent VW mechanic listen who believes part of the ‘mechanism’ behind vents has become loose. I have an appointment for a trim specialist to take out the trim and casing and inspect area behind for any obvious causes.
I have found a schematic plan for area behind the C pillar but not the area behind fans. The vehicle has 3 zone air conditioning, I have been unable to establish if the fans in that area have their own motor / condenser or something else sited in that area to cause such a rattle if it has become loose. If it is only air ducting I’m not sure how it is attached behind trim but doubt that could cause the noise. Even rocking the van from side to side can cause the rattle.
If anyone can help we would be very grateful and we certainly value the knowledge, time and effort many members put into making this forum so valuable.
Very much hoping someone can help.
Many thanks.
G
Many thanks.
G
