Chains for 235/55/R17 T6.1 -- roofbox says "vehicle and tyre size combination is not suitable for any traditional chains, and most automatic chains"
T
turnitdown
Edinburgh
T6.1 Ocean 150
Looking to buy chains for an upcoming trip to the Alps. When I put VW T6 2024 and tyre size into the snow chains search engine thing at roofbox.co.uk, I get this message:
"Our snow chains suppliers tell us that your vehicle and tyre size combination is not suitable for any traditional chains, and most automatic chains; this is probably because any chain links placed on the back of the tyres are likely to snag on the shock absorbers. We believe that all the chains shown below are safe to use; for example, ladder track chains do not put any chain behind the tyres."
They then give me some pricey non-traditional options (£325-£500).
Does this seem right?
Slightly related questions, does everything sold as a snow chain, even on eBay, meet a minimum standard for quality? I can imagine buying some cheap ones and the metal being absolutely soft and useless and them breaking the first time you use them.....
We’ve just comeback from 2300m in the snowy French alps.
If you can justify them I suggest getting snow tyres over chains, every single day of the week.
Chains are PITA getting them on and off the wheels. You can’t drive very far on tarmac in them without risk of damage. Most alpine roads are kept in good shape by the snow clearers.
If you’d prefer snow chains go to any large French/German supermarket near the alps. They’ll sell every size available for a reasonable price
thanks. I do have snow tyres, have just thought chains might be helpful/necessary too. Read some posts from folks in Livigno (which is one of the areas we are going to) and they said they were lost with just snow tyres and the chains saved them. Maybe it's overkill.
Before posting I had done a search on the site and didn't find anything that seemed that relevant, but using google just now searching for snow tyres VW California Ocean, I found this:
which suggests that, yeah, this tyre size is a problem for chains on the Cali.
I know that in fifteen years of driving vans and rear wheeled cars with snow tyres I’ve never needed snow chains.
I am biased though, I absolutely hate the things. We got caught in a blizzard once coming back to England and the traffic backed up. Why? Because of all those people stopping in the middle of the road to put on their chains as they didn’t have snow tyres. Grrrrr
The journey took eight hours door to door, unfortunately it was the same door, as we had to turn back
Livigno is at the top of and not far from Stelvio from memory. 2600m above sea level and pretty much snowed up this time of year. Stelvio can still be closed in May due to snow :)
We’re just asking the Mont Blanc end of Italy this week. Is Livigno to be recommended?
We could drive over
We could drive over
If you want to drive an extra 6 hours. I've been to Livigno on weekends a couple of times. It's ok but I honestly wouldn't plan a vacation there.
Did I understand correctly and you are in or around Courmayeur? If so then for a change of pistes you can go to La Thuile-La Rosière, Pila, Cervinia or Chamonix.
I've only used chains once in the last 20 years on my way (as it happens) to Livigno with my FWD Mini equipped with winter tires. The roads are typically cleared of snow pretty quickly, especially on hills, but if it is actually snowing while you're driving you will be sorry if you don't have chains.
  • Low profile chains are probably your best bet. They'll perform on both ice and snow but are a hassle to put on and take off as are all chains. Check out the (Thule) König XG-12 Pro.
  • Snow socks will get you through moderate snow, but not ice or heavy snow. They will wear down quickly on tarmac, so typically you can't just leave them on.
  • Don't even look at the nylon options. You'll be lucky if you get more than a few meters use out of them.
As my kids would say “like , ooh me god!”
Just driving back from La Thuile as I type, had a fantastic day skiing in both Italy and France.
A really brilliant place to spend a day or two.
Great suggestion. Thanks
It is indeed fantastic. I was in the area for 4 days from Thursday to Sunday but stayed in Courmayeur the whole time due to the strong winds in La Rosiere. I guess it must have improved after I left. I'm glad you had a good time.
Get some socks from Amazon
I was just in the alps and used These to get onto the campsite. They take lese than 3 minutes to fit and weigh nothing. In breaking tests they perform better than chains too.
If you want to go all in and you have 4 motion get 4.
Whatever you decide make sure you have a good set of working gloves to keep your hands warm and dry.
Winter (marked with 3 peaks and a snow flake) every time. Note these are not really "snow tyres" just tyres that function brilliantly in cold below 7c, on ice and, of course, in snow. Standard issue summer tyres in the above are pretty useless.
If you have them in the french Alps (not sure about other countries )you do not have to carry chains. I have two sets of rims, one summer tyres and one winter, changing them in April and November. Initial outlay a bit high...but, obviously, each set of tyres lasts "twice as long"!
I have 4 motion and 2 socks were sufficient
Hi, I also have this same challenge. Snow socks aren’t legal in some European countries and therefore not always the answer. Running 235 x 55 x R17 looks to reduce the clearance between the tyre and suspension components. VW do not sell chains for this vehicle / tyre (dealer feedback) and VW customer service unable to confirm clearance for me. Konig XG 12 Pro appear to be the way to go as only 12mm intrusion to back of tyre. Having measured yesterday there appears to be more than that clearance c.25mm+ on the front tyres.
All Season tyres these days are 3 peak mountain snowflake ‘winter’ rated and are great all year so don’t need to swap rims.
Not quite true...."all season" are marked M&S...these are ok in snow but you will still have to carry chains...at least in french Alps you do
Sorry, but that's not true. Most decent UK market 'all seasons' such as Cross Climates or Goodyear Vectors are winter rated with 3PMSF symbols. The Gendarmes are happy as they meet the spec.
In fact modern All Seasons outperform dedicated winters from a few years ago.
Last year for a trip in Europe I got the Husky snow chains from the club shop. They fit 235/55/17’s and I practiced putting them on several times before going- they fitted well. They seem a quality product and at £70 were inexpensive. Didn’t need them on the trip but have them in case.
Those definitely go on fine and tonnes of wheel arch clearance, but it’s clearance on the inside against the suspension struts that’s the likely issue.
You are correct...if tyre is 3 peaks and snowflake all will be happy
Good question. I’ve just put one on the passenger side. There is enough clearance for me to slide my fingers between the strut and the chain. My knuckles are a very tight fit. So, 2cm of clearance. Not being an expert in this, I’m not sure if that’s enough of a safety margin or not.
Try the group shop campervanbits they list a suitable set but we’re out of stock when i tried
Michelin Easygrip Evo 13 should do the job. I use them often on my Freelander and other vehicles and never had a problem. Relativeluy easy to mount too, as compared to chains.
