Californication69
Bill
Happy days, need a BF offer on a Vertuo Pop now..
I have 600 million Vertuo coffee pods to use
I will need to find the best way to plug the EcoFlow into my Victron too.we
why does it need the upgraded cable to the leisure battery? I thought the EcoFlow just plugs into the load side of the Victron?
Doesn’t the Ecoflow have an inbuilt charger? You need to find a way of plugging your solar panel directly to Ecoflow?I will need to find the best way to plug the EcoFlow into my Victron too.
I have a bus bar from the load side of Victron.
And it’s good for 20 amps.
So will need to find out how to recharge the EcoFlow from this
Yes it has quite a good MPPT actuallyDoesn’t the Ecoflow have an inbuilt charger? You need to find a way of plugging your solar panel directly to Ecoflow?
I wonder if I can hook onto the output from my solar PV and wire it into a (some sort of output plug) orifice to plug into the EF ?Doesn’t the Ecoflow have an inbuilt charger? You need to find a way of plugging your solar panel directly to Ecoflow?
If you try that I recommend throttling the input at the EF. The cable gets very hot.Found a post saying you can plug in using the 12v plug.
So I can plug direct into my OOWolf at 10amps.
Thread 'Charging a portable [solar] power station using the California Beach inverter.'
https://vwcaliforniaclub.com/thread...on-using-the-california-beach-inverter.51829/
Throttle to 6amps?If you try that I recommend throttling the input at the EF. The cable gets very hot.
That works for me. I had it set to 10A and connector partially melted.Throttle to 6amps?
Watts, power and amps like to try and kill usThat works for me. I had it set to 10A and connector partially melted.
Actually the 1500 is £999, which is a bit higher. The like-for-like 1000 is £709, with a free 100w panel was nearest I could find. Though I'd still stick with the Bluetti AC200MAX for the extra pennies. Mine has powered an air fryer, coffee machine and even a hair dryer while camping!Where are you seeing that? Cheapest I can find it is £999. Also looks like the Delta 2 has a 5 year warranty.
uk.jackery.com
Didn’t mean a haha. I meant a Thanks!
In a campervan you absolutely want the safest chemistry ie LiFePO4. Its not even a consideration. Plus you get 2x the number of charge cycles ie 3000 if memory serves, without significant hit on capacity.I’m looking at a couple of Ecoflow Delta 2s - can anyone recommend the practical use case difference between the following?
ECOFLOW DELTA 2 Portable Power Station 2400W Max LiFePO4 Battery Solar Generator
ECOFLOW DELTA 1260Wh Portable Power Station 1800W Solar Generator for Camping
Is it just the peak W? And generation? If so is it worth the up spend for the former?
Thank you. Very succinctIn a campervan you absolutely want the safest chemistry ie LiFePO4. Its not even a consideration. Plus you get 2x the number of charge cycles ie 3000 if memory serves, without significant hit on capacity.
Heeded your advice , bought a LiFePO4 Delta 2 refurbished from Ecoflow’s eBay store.In a campervan you absolutely want the safest chemistry ie LiFePO4. It’s not even a consideration. Plus you get 2x the number of charge cycles ie 3000 if memory serves, without significant hit on capacity.
There is some great pricing nowadays. Mine cost 2x that even with a VAT rebate. I am seriously considering an extension battery pack if I have space in the boot after I get my Brompton.Heeded your advice , bought a LiFePO4 Delta 2 refurbished from Ecoflow’s eBay store.
£525 delivered. Seemed good value as retains manufacturer’s warranty. Albeit shorter. But hopefully 2 years does it.
So you have your CTEK running off a power bank?I purchased the All powers and ctek charger just to keep engine battery topped up as I have no power near cali , just plug it in once a month
