Tarquers
Very useful. What is the app please?Following on from a friends misfortune with DPF, installed an app which provides monitoring via CarPlay. Carista dongle and a pay once app from the App Store very happy so far allows tracking of soot levels and shows an alert when regen is taking place but cannot force a regen View attachment 117813
This intrigues me. Can someone explain the value of the above app, as I suspect i'm missing something out and that bugs meFollowing on from a friends misfortune with DPF, installed an app which provides monitoring via CarPlay. Carista dongle and a pay once app from the App Store very happy so far allows tracking of soot levels and shows an alert when regen is taking place but cannot force a regen View attachment 117813
Yes. Needs a device like Carista and need to select the right engine to get accurate data but impressed with ease of use and the CarPlay interface
$4.99 one time purchase. Seems like an excellent investment. Found myself turning off the motor mid regen without realising. I want to avoid a repeat performance and this will give a headsup when region will occur or as Tarquers says an opportunity to force it during a longer run.
The EVO seems to be an upgraded version to the original unit. Says it's faster with a broader range of vehicle compatibility. Personally I don't see any advantage for us (Transporters) to pay 2x the priceAnd what’s the difference between the carista gen2 and Evo?
But wait, you think your TSI engine isn't prone to carbon buildup..... think again. All direct injection engines suffer this problem. Big issue with the flat 6 Porsche engine, same for the Audi V8. Loads of examples on VWVortex regarding TSI. At least the Transporter has a system to deal with the problem. Good luck with your TSI.Oh for a Tsi California. Oh but wait, the California Concept has a Tsi variant.
With the journeys that I make the TSI will suit me fine, and I won't have to worry about Adblue faults or a replacement DPF . Use it or lose it is a good rule of thumb for diesels and less so for petrol plus the saving on ULEZ both in the UK and continent will help.But wait, you think your TSI engine isn't prone to carbon buildup..... think again. All direct injection engines suffer this problem. Big issue with the flat 6 Porsche engine, same for the Audi V8. Loads of examples on VWVortex regarding TSI. At least the Transporter has a system to deal with the problem. Good luck with your TSI.
No it just uses the device.Do you need the software for Carista to be installed too, with the monthly service fee ?
This has been a very helpful post/thread - thank you. So to be clear one just needs to purchase the Carista dongle, plug into OBD port and then 'just' download the DPF for VAG app and NOT the Carista app (unless one wanted those extra features)No it just uses the device.
Correct.This has been a very helpful post/thread - thank you. So to be clear one just needs to purchase the Carista dongle, plug into OBD port and then 'just' download the DPF for VAG app and NOT the Carista app (unless one wanted those extra features)
I purchased carista device and downloaded the software but free only. I also bought the VAG DPF app. When you plug in carista you get a red light for power and then when you connect via Bluetooth you see communication as a flashing blue light.This has been a very helpful post/thread - thank you. So to be clear one just needs to purchase the Carista dongle, plug into OBD port and then 'just' download the DPF for VAG app and NOT the Carista app (unless one wanted those extra features)
Thanks - that's helpful and good to know.I purchased carista device and downloaded the software but free only. I also bought the VAG DPF app. When you plug in carista you get a red light for power and then when you connect via Bluetooth you see communication as a flashing blue light.
It is important to select the correct engine type so that the CANbus data is correctly interpreted.
It’s a passive device so you cannot force a regen, paid carista for that but despite limitations worth the money.
