Corradobrit
For some reason it is deleted on my MY23 Coast. Someone else with an Ocean said the same.
vwcaliforniaclub.com
Its not clear how its secured. The T6.1 Coast and Ocean don't have the tie down bar on the interior molding and the contact points of the thin perspex plates is not going to be sufficient to enable use of velcro. I would want some clarification on the installation before committing.Is there a reason not to consider this item? It is more expensive. I am thinking of purchasing this.
Genuine VW California SE/Ocean Safe
Genuine VW California SE/Ocean Safe, fits securely in the base of the wardrobe to remain secure and discreet, genuine Volkswagen Productvwcaliforniaclub.com
If you have the tie down bar below the 12V socket then yes. Other wise maybe. Adhesive velcro is used to secure the shoe boxx to the step and flooring. I guess if you were to use the industrial type 3M mushroom velcro a single strip on the floor section might work so long as the carpet doesn't life the shoeboxx too high.Probably a silly question but can you use one of those shoe storage things if you’ve got a step mat?
Thanks. I will ask how it is secured.Its not clear how its secured. The T6.1 Coast and Ocean don't have the tie down bar on the interior molding and the contact points of the thin perspex plates is not going to be sufficient to enable use of velcro. I would want some clarification on the installation before committing.
Also might need 2 hands to access the lower shelf to move the bungy cord out of the way.
I bit the bullet and got the Cinch Hub and an Outwell freestanding inner. Will not be testing it until the end of the month, but Seb is hopeful about more space for him and I am happy about it being lightweight and not requiring attaching to the van.
I noticed that last night as well, I am also tempted. Those 2 make me laugh!Just when I thought I’d got every kitchen gadget for the van I could need, I saw Bob Mortimer using this pull chop thing on his fishing programme last night and talked myself into getting one to try for myself!
Pull Chop Small 500ml
A handy manual food processor to cut herbs, vegetables, fruit and morewww.kuhnrikon.co.uk
You need to turn the tap on occasionally to stop the pump from seizing up .Get the old 1 back it probably just needs the impeller turning by hand to free it.New fresh water pump. Well, via the garage not me personally - too difficult to access. Bit poor it failing really - van has v low mileage and consequent low use of pump.
Nice!For those of you at Slimbridge who asked to see pictures of my car port here it is. Now that we have it in the correct position it will be fixed into the drive. £1599.99 delivered from Costco. Hopefully will keep the worst of the weather and the pesky pigeons off!
Hopefully! It is being secured to the drive with special bolts.Nice!but will it hold in a Gale?
Also …… a real postbox?![]()
OK so I should have read this before collecting the van this morning! Never mind, tip re running the tap useful though! ThanksYou need to turn the tap on occasionally to stop the pump from seizing up .Get the old 1 back it probably just needs the impeller turning by hand to free it.
Just trying to help you and others in the same postion as yourself .OK so I should have read this before collecting the van this morning! Never mind, tip re running the tap useful though! Thanks
Fits well.View attachment 115363
A bin. How exciting!
Had them on sale in Tesco. Is a Curver.Fits well.
