You could even do this really simple DIY-hack. Add a thermometer. All you need to be able to do is drill a hole.
What about an Air fryer?We want an oven in our California T6.1 what's the best option? Has anyone got one?
You just need to be careful of the wattage. One I was looking at yesterday was 2.8kw. Which would cause a power trip on many sites.What about an Air fryer?
We have a Remoska, which we find very good. They are available from Lakeland.We want an oven in our California T6.1 what's the best option? Has anyone got one?
I suppose you may need one of those power stations to run it rather than hookup then.You just need to be careful of the wattage. One I was looking at yesterday was 2.8kw. Which would cause a power trip on many sites.
This is very similar to the one we bought from Aldi. the 3 knobs are for Timer, temperature and which elements you want on Top or bottom or all. They are cheap enough to throw away if anything goes wrong. But ours is about 3-4 years old and no problems at all. We even occasionally use it in the kitchen as it’s much cheaper than a conventional oven.I suppose you may need one of those power stations to run it rather than hookup then.
I’ve seen campers with ovens installed like this, but they must have a more powerful inverter:
The tefal one is less than 1400W. Ultimately, I guess it comes down to how much stuff you want to carry and how you like to cookThis is very similar to the one we bought from Aldi. the 3 knobs are for Timer, temperature and which elements you want on Top or bottom or all. They are cheap enough to throw away if anything goes wrong. But ours is about 3-4 years old and no problems at all. We even occasionally use it in the kitchen as it’s much cheaper than a conventional oven.
Anyone using the SQ Professional in the video, instead of RidgeMonkeys ? Love the compact nature of the RMs, so much that we have 2. But I find the quality isn't great. Customer service has been good enough to replace handles that have failed, but I am sure they will fail again. The SQ looks robust, but I would worry about the size of the pan being too big for the Cali hob, so curious if anyone has used it?@8:00
Yes, it's something like that we were thinking of. You ran it when hooked u then I assume using the 3 pin plugs near the sink?This is very similar to the one we bought from Aldi. the 3 knobs are for Timer, temperature and which elements you want on Top or bottom or all. They are cheap enough to throw away if anything goes wrong. But ours is about 3-4 years old and no problems at all. We even occasionally use it in the kitchen as it’s much cheaper than a conventional oven.
Yes, you're right we will need either a roof box or a little trailer at the rate we are buying things for our new van.The tefal one is less than 1400W. Ultimately, I guess it comes down to how much stuff you want to carry and how you like to cook![]()
We have a awning room that we cook in which helps with less clutter in the van. Yes we use the plug by the side of the sink but we have a 4 plug adapter we plug everything into but always consider not overloading the system. Everything we use as an appliance is low wattage except the 2 kw fan heater which we don’t use with anything else as its certain to trip the campsite fuse. The cooker will only work while on hookup.Yes, it's something like that we were thinking of. You ran it when hooked u then I assume using the 3 pin plugs near the sink?
Wow! A 2kw fan heater to warm your CaliforniaWe have an awning room that we cook in which helps with less clutter in the van. Yes we use the plug by the side of the sink but we have a 4 plug adapter we plug everything into but always consider not overloading the system. Everything we use as an appliance is low wattage except the 2 kw fan heater which we don’t use with anything else as its certain to trip the campsite fuse. The cooker will only work while on hookup.
