Peter Horvath
Hi,
I have a new T6.1 ocean. I filled the water tank with fresh water, played with the sinks just to test it out. Then I tried to empty it by turning the valves to open, but nothing comes out, even if I drive with the car. It starts bubbling like sucking air, but nothing comes out and the water is still there. I emptied it out using the shower, now it shows empty water tank, but I have grey water tank that is filled. Also opened the valve under the sink and I hoped something would come out. The display shows the grey water tank is not empty I do not know what to do.
Searched forums, I will try to stick something through the pipe for grey water, but it is a new car, so nothing should be stuck and I only put clean water down the drain (from the sink). Is there something else I need to do in order for the tanks to empty, in addition to opening the valves under the sink (grey) and next to the gas tank (fresh tank)?
Thanks!
Thanks!
