F
far.landscape
Hi all, I have found that the leisure battery in my GC600 is not charging while the engine is running, regardless of whether the dash button is pressed or not.
I have been able to fully prove this now I have a bluetooth battery voltage gauge attached directly to the leisure battery. The voltage is constant (and dropping, unless solar is contributing or on hookup) irrespective of engine state. Solar and hookup charging works as expected, but never any engine charge contribution.
I believe from previous threads that it should charge while the engine is running, although I could be interpreting that wrong, and was not clear if this would only be the case while the dash button was pressed. Regardless, it is never charging at all while the engine is running, regardless of the dash button, unless the solar is giving a charge, or when on hookup.
Does anyone else recognise this issue and happen to know any potential fixes before I have to make the long trek to the dealer? Or am I wrong to expect a leisure battery charge contribution while the engine alternator is active? I had thought it was a split charge system. I have not measured it, but judging by the vehicle startup behaviour, I'm pretty sure the vehicle battery is in good condition, and the leisure battery is brand new and in excellent condition.
The dash button I'm referring to, for reference (it does light up when I press it while the engine is running, but it has no impact on the voltage of the leisure battery regardless of how long it is left on)...
