Cali Phillip
Always the same room as i say wherever you park itNew U.K. stickers.
I notice you have some carpet on the ground @marcdavis and assume that’s because the black plastic by the tail lights is grounding? I did the same for a while until I realised that by tilting the rack towards the van more when mounting it, the rack then didn’t ground itself. Takes a bit of practice getting it right.Thule VeloSpace XT3 bike rack. Very pleased with it. Easy to mount (a bit of muscle required!) Very easy to tilt. And, as others have already confirmed, it tilts just(!) enough to allow the tailgate to open. It’s a quality bit of kit.
For when?![]()
A train ticket!
Hi GG. The carpet was more a precautionary measure whilst I was fitting for the first time. But you’re right, you do need to mount it tilting slightly towards the van. I needed to adjust it a little after the first go. All good though. I also just added the extra bike adapter which was easy enough. Plus the number plate (purchased from number1plates.com). Will load it up with 4 bikes this weekend and give it a proper test.I notice you have some carpet on the ground @marcdavis and assume that’s because the black plastic by the tail lights is grounding? I did the same for a while until I realised that by tilting the rack towards the van more when mounting it, the rack then didn’t ground itself. Takes a bit of practice getting it right.
Pictures or it has not happened!Used Eva to collect 3m fence posts today also
That's a good price,909 and 907 Camping Gaz refill. £35.
Hi I can confirm this is a good bit of kit bought the same rack works really well with my mountain bike and ebikeThule VeloSpace XT3 bike rack. Very pleased with it. Easy to mount (a bit of muscle required!) Very easy to tilt. And, as others have already confirmed, it tilts just(!) enough to allow the tailgate to open. It’s a quality bit of kit.
Part one is the prep and glue of the Velcro strips to the metal work so not much to report other than it was the first time I had really looked at the whole of the roof space. Saw the way the mattress was made at the foot and used the 2nd hand ladder to get up and down a dozen times. Then to leave 48 hrs to cure.Pictures or it has not happened!![]()
That comment was for the fence postsPart one is the prep and glue of the Velcro strips to the metal work so not much to report other than it was the first time I had really looked at the whole of the roof space. Saw the way the mattress was made at the foot and used the 2nd hand ladder to get up and down a dozen times. Then to leave 48 hrs to cure.
Agree @Calimili , one of the key shortcomings of the Cali. Even with the cupholder on top of the dash, you have to reach to get to it. This one - don't even have to move an inch.
On the measurements, see pics. .IMO, the bottom does not matter too much. One of my water bottles has a larger base but it's sits well.
The top is 7.5 cm.
The bottom is 6.25 cm
A Costa cup sits well.
My water bottle sits in place. 300 mls yesterday and it was all good.![]()
The passenger will have to do without as of now ... they have to ask
No pictures of the 10 fence posts. Used a large plastic bin placed on it’s side as the end receptacle on the passenger seat to keep it all safe and protect the front.That comment was for the fence posts
Do you have a link to where you got them from and is it a t6.1
