    31st October to 2nd November
    Everyone Welcome
    More Details Here
View from/of your van.
Rainy day - the van/California is best for it! Went to a tiny place to ski and enjoyed the parking lot with my godchild, brother and son. California is best for changing wet clothes
Well done, where to.
I’m confused. I thought if you were from a Zone 2 area, you should not travel to a Zone 1 or 3 area. On the attached map of Scotland only the red areas are zone 2. Fairly limited where you can go or am I reading it wrong?
Is that the Vanstyle front splitter Ray? Looks good, I have been thinking of getting one. Was it easy to fit?
Hi... Yes it is the Vanstyle one I thought I would take a risk on the fact that it already a gloss black and seems to suit. I am toying with the idea of spraying it matt black or the same red as the Cali but lets see.
It is easy to fit but was tricky to centre (I was probably being a bit fussy).
It comes in 3 parts (red arrows) with just self tap screws to hold together. I put some double sided tape where the green arrows are to aid lining up. When I was happy with that I drilled the small holes required in the original valance (If you had to remove later you wouldn't see them)
Then it is self taps through the plastic to secure. I have tested out on the motorway at above legal speeds and all has been OK.
Thanks Ray - looks like a job for when the weather improves! Did you get the front end off the ground? I think it would look wrong in black on my Bay Leaf Green lower half so I would have to get it colour matched. Thinking about it...also the side bars like yours!
YorkshireHeathen
YorkshireHeathen
Beachbum140
7K
Bulliturk
Bulliturk
