Good that a solution has been found for this. Just for completeness, can you explain the order that you removed, and more importantly replaced the fuses? Was it all out, then replaced 5, then 6, 7, 8?Same problem today - roof did not want to close - pulled out and in all 5-8 fuses and panel reset - roof closed after thatView attachment 63304
Replaced them in order 5 to 8 - did not replace them just in/out and control unit was resetGood that a solution has been found for this. Just for completeness, can you explain the order that you removed, and more importantly replaced the fuses? Was it all out, then replaced 5, then 6, 7, 8?
Very useful thanks. I’m also awaiting delivery of a new T6.1 so it’s good to be prepared for this roof problem should VW not sort it out in the coming weeks/months. It would seem a much better/easier fix than removing the camper control panel and hacking away at foam rubber to reach the manual lowering screw as discussed in other threads.Replaced them in order 5 to 8 - did not replace them just in/out and control unit was reset
I’m probably being thick - I’m not sure I follow. Does this mean ignition off then remove the four fuses? Then ignition on to make it ‘crash’ then turn ignition off again? Then replace all four, then ignition on again to force a reset?Replaced them in order 5 to 8 - did not replace them just in/out and control unit was reset
no ignition involved, just pull the fuses and let the unit discharge/reset.I’m probably being thick - I’m not sure I follow. Does this mean ignition off then remove the four fuses? Then ignition on to make it ‘crash’ then turn ignition off again? Then replace all four, then ignition on again to force a reset?
OK thanks. Does it matter what order you take out and put back?no ignition involved, just pull the fuses and let the unit discharge/reset.
It definitely sounds like there is an issue with the software where it barfs at the point it should be checking the roof position.So it's tomorrow... lights wouldn't work at all and no tick... key in ignition tried to lower roof and get the check roof position method, decide to lift roof, it goes up a smidge and all is well with the world again. A good start to the day
We had that problem on our 2019 Cali, new fridge fitted under warranty.Fyi, keep an eye on your fridge symbol in the camper unit. That thing turned itself off 2 times the last weeks. My milk was Joghurt![]()
Hi Loz, thanks so much for this advice! I was stuck at the Baltic Sea shore in Poland with the same problem and you totally saved our vacation. Removing the four fuses worked twice for me (I had the same problem two days later again)!The Control panel on the 6.1 now talks to a new special vehicle control unit that is supplied by 4 fuses. You could remove all 4 fuses and see if that power cycles the unit.
Fuses 5-8
View attachment 59052View attachment 59053
Hia, I'm stuck in Italy with the roof open on my T6.1..... VW are useless, was going to try to remove and refit fuses5 to 8 but my fuses behind the steering wheel look different to the above diagram- see photo. Any help would be greatly appreciated.The Control panel on the 6.1 now talks to a new special vehicle control unit that is supplied by 4 fuses. You could remove all 4 fuses and see if that power cycles the unit.
Fuses 5-8
I think it's those 4 brown 25A fuses to the right next to the 646. Try removing them and see if the control panel goes off. You can't do much harm even if they are the wrong ones.Hia, I'm stuck in Italy with the roof open on my T6.1..... VW are useless, was going to try to remove and refit fuses5 to 8 but my fuses behind the steering wheel look different to the above diagram- see photo. Any help would be greatly appreciated.View attachment 65413
