Mo!
1st van 2012 to 2016 second van 2016 until today - not a lightweight and not managed to break one yet. Interesting that you have broken 2I have now got both camping seats broken in the same place.
I don't know if VW sells parts for the chairs.Mine fit the purpose of which they are intended.
It could be that there was a bad batch of plastic elbows so it is
worth checking with your dealer.
Although i would think they would only supply the parts and you would have to
fix it yourself.
Im out of sync, but isn't shouting - not fit for purpose - a bit of a chavvy thing.
I did get some screws and washers for the chairs fromI don't know if VW sells parts for the chairs.
They just want your €100 or more for a new chair.
Despite what some people will tell you, this is a common issue with these VW picnic chairs. There is a design fault in the plastic joint shown in your photograph. It fails because this cheap plastic component has a hole through it to take the securing pin/rivet. The hole provides the built in weakness. And before anyone starts banging on about the weight of the person using the chair just bear in mind that this part isn't load bearing. It merely joins the arm to the top of the front leg frame.Hi all. I have now got both camping seats broken in the same place. These have not been misused at at all, and will be very expensive to replace. Is this a manufacturers issue that I should have replace t’s for? The van is 3 years old.
Thanks for the info, but luckily I haven't lost any screws or bits of those chairs yet.whaug@camping-schuh.de
Here it is. Pop him an email and he should be able to sort
you out. He did with me, although it was 8yrs ago.
I never knew i had so many Wolfgangs in my inbox![]()
I did know that you would know that info.Thanks for the info, but luckily I haven't lost any screws or bits of those chairs yet.
I always keep an eye on my stuff, and as soon as I see something not correct, I try to mend it before it breaks down.
All you need is a Philips screwdriver and an allen wrench.
Bit unnecessaryMine fit the purpose of which they are intended.
fix it yourself.
I also have a pair of cheap tubular fold away camping chairs that I bought from a motorway services about twenty years ago. They too are über comfortable and still going strong. They cost about £10 each from memory. I have never found the VW chairs that comfortable and no longer trust them.I had some ‘Lafuma’ camping chairs that I bought in about 1997 that went all over the place camping and ‘lived’ in the garden and I’ve only just taken them to the tip. And they were a fraction of €100 for the pair. Bloody comfortable too.
Ive never used mine, and always carry additional camping chairs.I also have a pair of cheap tubular fold away camping chairs that I bought from a motorway services about twenty years ago. They too are über comfortable and still going strong. They cost about £10 each from memory. I have never found the VW chairs that comfortable and no longer trust them.
See "load through hatch"#34. I too have doubts about the VW chairs, on pulling out when being demonstrated to me, a number of loose screws also dropped out. Although that was easily fixed, I don't find the chairs comfortable and so decided to make space for my generic folding canvas chairs bought at a show in 1991 for the princely sum of £5 each. They are now repaired with leather patches over the canvas stress points, but are very comfortable.I also have a pair of cheap tubular fold away camping chairs that I bought from a motorway services about twenty years ago. They too are über comfortable and still going strong. They cost about £10 each from memory. I have never found the VW chairs that comfortable and no longer trust them.
Beer related?one of mine broke in the exact same spot.
AwninggateBeer related?
Ha. Not that timeAwninggate
