Scoobz1
I would have suggested changing your shopping times, using a different local super market /shop, finding out the best delivery times or even doing without ... the same way you manage through the shortage of anything else ...
Anyway with a near non existent egg supply in Greater London, I would suggest you keep your chicks under cover! On a more serious note though (apart from being a bit of a bind when you go away) chickens inevitably attract rats. Even if your chickens are enclosed in a run, rats will come underneath it to get the food if it hasn't got a concrete or mesh sub floor and breed like the proverbial, well, rats.
If you have a rat-proof area where the chickens can feed, it is worth removing the food and storing the food somewhere else, for the rest of the day, if you want to let the chickens out to mooch around and be free to return. When you feed the chickens initially see how much food they generally use . If consumption suddenly starts to go up then you will know you have the start of a rat problem. Also keep an eye out for tunnels. Things can get out of control very quickly if rats can access the chickens food supply.
