How did you manage to move your house?I used to stand on the low dividing wall between my house and next door and clean it with a long brush attached to the hose. Will have to come up with a new plan as I have recently moved house.
I use a step platform, the type used by plasterers.
The process I use is:
1. Jet wash the roof first to remove grit etc. This is most important as there is usually loads of crud in the indentations.
2. Snow foam to loosen the remaining grime.
3. Jet wash the snow foam away.
4. Brush the roof using one of those soft long handled car cleaning brushes attached to a hose.
5. Then a quick go over with a soapy wash mitt.
6. Jet wash.
Sounds complicated but I'm a fussy ...........
www.clarketooling.co.uk
Step ladder and long handle brush.not sure if anyone has asked this before but what do you use to clean the roof? Normally I would start on the roof but reaching is an issue and don’t really trust myself not to tip the ladder into the Cali and dent it ☹
Me too, I struggle to reach across the windscreen tbh and I’m 6 ft 5.How did you manage to move your house?
I just stand on a ladder. Even with my 1,95 meters of height, I can't reach the roof properly to clean it.
