MeltedGoldfish
Hi all,
Just picked up our ‘new’ (well, 2012) California SE, first Cali and camper, but already having a battery problem which manifested as soon as we turned up at our first campsite (90 minutes after collecting the van…). Have got in touch with the dealer (it did come with warranty!) but not convinced by their knowledge so after your collective thoughts.
After turning up at the site, we plugged it into the mains and got the correct plug symbol indicating it was charging. Was on charge for around 18hrs, disconnected in the morning but after just an hour (with everything switched off) I got the battery caption. Had to start the engine to lower the roof. With engine running I got the ‘G’ caption indicating the battery was charging fine.
Got home (1:30 driving), went to raise the roof and had the same battery issue. After a bit of playing around, including resetting the CU and looking at the diagnostic menus, I’ve deduced the following:
- When plugged into the mains, the plug symbol shows, the battery is at around 14V (see below for current).
- When engine is running, the G symbol shows and battery is at around 14V, and around 4A.
- As soon as the engine is turned off it shows 14V, 0A and 100%. However, within 5 sec this dropped to 12.5V, -0.6A and 90%, then a few seconds later to 11.6V, -0.4A and 0%.
I’ve just plugged it into the mains to charge again overnight and see what it looks like tomorrow. At the moment it’s showing around 14.2V again, with current around 8A, then dropped to around 5A but seems to have stabilised around 7.4A.
Given it appears to be charging on both mains hookup and engine, and had 18hrs on hookup plus a few hrs driving, I’m guessing this sounds like it’s the batteries that are shot and not holding charge (as opposed to a charger issue or blown fuse, as per some of the other forum posts)?
I assume a ‘positive’ current is a current into the battery, ie charging?
Thanks in advance!
Thanks in advance!
