Drpps
2014 2.0tdi 140 bluemotion.
I have started to have this error pop up in the MFD. It started a month or so ago. I have since then driven 1200 miles around France on long journeys at motorway speed so shouldn’t be a regen issue. I have also given it a good ‘drive’ and with the revs held above 2000rpm.
The engine starts normally without an error. Once warm it sometimes goes to fast idle at 1000rpm with the error. Even after an hour of fast motorway driving it hasn’t gone away This is different to a regen cycle when the ‘A’ with the line through it lights up or any of the other reasons for it to disable itself and when regening you can hear the fuel pump sending the extra fuel in which it isn’t doing.
On other occasions it works perfectly normally. If you turn it off and restart it also works normally.
I know there are a multitude of parameters to prevent stop start functioning but they shouldn't lead to an error message. It has been consistently plugged into the mains/ on hook up for more than 24 hours and charging correctly so shouldn’t be a battery issue. I am going to scan it with VCDS when I get a chance but any suggestions?
