SusiBus
2-pedal power Peppa Pig trike
Am I being stupid, isn't the answer obvious, tape under the rubber seal?
If I ever find corrosion on my roof it would never be going to any VW Dealer even if under warranty! Clueless every single one.
All T5s from 2010. Only relates to Galvanic Corrosion on the Elevating Roof beneath the steel reinforced rubber seal around the edge.what I am still trying to work out is this
is this a new preventative procedure that includes T5s that have had the full roof/front panel corrosion done previously ... and does every T5 get it it ...
or is this something they are doing because they have checked and actually found an issue on my bus, despite the previous "fix", that now needs additional procedures..
the bod on service desk at Listers not really able to answer that for me....
What I think VW have come to realise, is that even if you have had a repair, there is a good chance the problem might reoccur unless they isolate the roof from the seal. So they are adding the tape or foil as they are calling it.what I am still trying to work out is this
Hi @Billywizz just wondering why you say ever single dealer is clueless have you had bad experiences? I don’t want to divert away from this thread as it’s on everybody’s mind at the moment. But we are not all clueless.
Hi yes I know marshals were because they were following the workshop manuals as it should be. When claiming we as a dealer we ended up footing the bill as vw would not pay us for the tape they said it was not part of the repair at the time. FYI the process to bond the seal back on has now been removed from the process.
Hi unfortunately I cannot up load the information as it is copy right protected however what I can tell you is that the information on the workshop systems no longer instruct for the seal to be bonded to the lifting part of the roof. It was there until a few months ago then the information to bond the seal was removed. Who ever at be told you that it is still the correct procedure is wrong.Hi Vw Guru, do you have and information on bonding the seal not being part of the process? We got our Cali back a few days ago from Claridges and they have bonded the seal. VW are saying this is still the correct procedure. I would rather it had been tape as now hard to inspect further corrosion. Thanks
as I don't know what to think.Hi Brandi,VW Guru, thanks for the replies.
I spoke to SMG Cowfold and VWCS (via technical department) today and I'll try and explain what they told me.
As I understood it there as are two separate processes.
If there is corrosion below the seal the VW garage has a process to follow which involves removing the seal,, treating the corrosion area, before adding the tape and then manually refitting the seal (not bonded).
This is specifically for VW Garages.
If corrosion is found above the seal then the VW garage do not carry out work and the vehicle is sent to an authorised body shop (eg claridges) for them to do the work.
This is governed by a different manual and process.
That process involves removing the seal, treating the affected area and then replacing the seal by bonding it back on.
Both claridges and VWCS confirm this is the correct, up to date process.
As it was explained to me, if the roof seal is bonded there should be no need to carry out the workshop recall with replacing the tape as the recall is only for vehicles where no corrosion is found.
Please bare in mind this is what was explained to me by SMG (who have no personal involvement and I believe are one of the more knowledgeable dealerships) and I am by far am expert on roof corrosion issue.
To be fair I am nowas I don't know what to think.
Sorry if this confused matters further.
Hi @Vw guru you say that there is a distinction between below the seal and above the seal, but our roof only had corrosion under the seal and was sent away to Claridges in July. They bonded the seal back on. I'm sure there are a lot of other owners who have only had corrosion under the seal and have had this repaired by body shops.Hi @Daisymaisy this is an interesting statement
, as dealers we are told to repair corrosion below the line of the seal then fit the tape and a new seal if required. We have to follow the workshop/ body shop instructions that are on the same vw system we all have access to. I will be speaking to marshals body shop on Monday to see what they are instructed for corrosion over the seal because all of us have access to the same system/ repair procedures and nothing states that the bonding should not be carried out by dealers but should be carried out by body shops. I will let you all know
Of course as we've said here, the workshop action was carried out on ours in October/November which wrecked the seal and didn't clear the sealant before the tape was applied.
There have been a couple of members who have reported recently that their vans just back from bodyshops have had their seals bonded back on, instead of having tape applied as per the workshop action instructions.
So is it just that VW haven't clearly instructed the bodyshops about the new method, have they simply not realised that the two sets of instructions are mutually incompatible and not informed the bodyshops or have some bodyshops not revised their procedures.
One way of seeing what has happened would be to look at the parts list for the bodyshops for the corrosion repair. When ours went away the list included the sealant for bonding the seal on. If the parts list still includes this, then the bodyshops will still be bonding the seals on when the repairs are done.
I'm guessing that the parts list still includes sealant and that VW haven't changed the instructions for the bodyshops.
Hi @Bramco as of the workshop action (recall) the instructions are the same for body shops and workshops the only difference is if the corrosion has traveled above the level of the seal then we have have to send the vehicle to an approved body shop to have a smart repair carrier out on that section of roof. If it’s below the seal level then the repair work is carried out by your dealer in there workshop. Neither the body shop or dealers are being instructed to bond the seal as that has been removed from the work instructions. Once the paint repair is carried out either by the dealer or the body shop then the foil (tape) must be installed, the roof seal must then be inspected if the seal is ok and not rusting or rubber broken it must be refitted if the seal has problems then it must be replaced. To be honest nearly every seal I’ve seen is split and having to be replaced I think I’ve only refitted one in the whole time I’ve been carrying out this repair.
Check out post 310 in this thread Just announced - T6 recall for roof corrosion beneath the seal
Bodyshops are still bonding the seal on.
It effected mine built November 17. I don’t think there has been any changes.does this affect Cali's built in 2018 onwards?
It
