Amarillo
Tom
My sliding door handle has worked it's way loose. Is there a simple way to tighten it or do I need to find a service centre?
Suspect a dealer visit maybe required. Will be interesting to see how Spanish dealers compare with Polish ones.
They were unable to fix the handle as they need to order in the part. They've phoned ahead to Gijon to order the part so we can get it fixed on Monday or Tuesday. Apparently it's a 2 hour job. @Borris might say it will be a "simple warranty claim", and I might reply, "there ain't such a thing".We have an appointment at Rioja Motor for repair at 3pm.
Looks like there is nothing to pay. Warranty issues within the first two years only are a simple matter within the single market area. More complicated in the third year as VW's standard warranty is 2 years, VWUK give 3 years as standard. Yet more complicated outside the UK if you have the extended 5 year warranty.I agree with your post 9 BUT, it is passing the buck to the next garage. I also agree the door handle should be repaired FUG
...Apparently it's a 2 hour job....
In the UK years 1 + 2 are via VW and year 3 is a Dealership warranty. 3 rd year can still be used at any approved VW Dealer. Something to do with Consumer Regulations , I think.Looks like there is nothing to pay. Warranty issues within the first two years only are a simple matter within the single market area. More complicated in the third year as VW's standard warranty is 2 years, VWUK give 3 years as standard. Yet more complicated outside the UK if you have the extended 5 year warranty.
My explanation was not 'how to fix it' but how to remove the trim to see the issue inside the door - and that is indeed a 2 min job for a mechanic with a Torx wrench and a pair of hands.![]()
What parts were fitted? If any
I'd say that might be the likely cause, my youngest hasn't quite got the strength to open the door but he keeps on yanking the handle.Two chargeable parts - some sort of internal catch and another bit or bits. WiFi here is lamentable and 3G phone is, at best, one bar. When I can I'll photograph the invoice and post it.
I think that the cause of the failure was repeated and determined efforts by a 3 3/4 year old boy to try to open the door.
My children, 9 and 7, constantly hangs down when opening the door. I am always yelling to them, only outward and backward, not down. I dont think the handle will last the vans life at all.Two chargeable parts - some sort of internal catch and another bit or bits. WiFi here is lamentable and 3G phone is, at best, one bar. When I can I'll photograph the invoice and post it.
I’ve spent less than that on buying a car!Loose sliding door handle now fixed by VW, description of work was "stripped down door handle assembly found inner parts had fallen apart, rebuilt, remitted and secured, test all ok" Bill for that was £180 plus vat = £216 for the two hours of labour.
I do recall having to give the handle a really hard tug a number of times when frozen solid, must remember not to do that in future! Just open from inside.
