R
Rob C
For many weeks I have been agonising as to which 3-4 bike tow-bar mounted bike rack to purchase. I couldn't seem to find a definitive answer as to whether any models allow the tailgate to be lifted without fouling the rack or bikes. For 3-4 bikes the choice seemed to come down to the Atera DL3-4 or the Thule 928/9.
The Atera seems to be many people's firm favourite, albeit that the inner bike would need its handle bars turning. I was keen to avoid doing this as it's not that easy on our bikes.
The Thule looked to be a viable option, but as mentioned, I couldn't get a clear answer as whether it too required the handle bars to be turned.
I therefore ended up buying both (don't worry, one's going back!), and I hope the following will help others asses the obvious difference.
My vehicle has a Westfalia after-market removable tow-bar. I think the make and type of tow-bar does make a difference as obviously they (apparently) vary in height and distance from the vehicle etc. So my findings are obviously only related to my type of tow-bar.
Atera DL3-4
When slid away (tilted) this rack doesn't actually allow the tailgate to open even without bikes fitted. It's actually very close, and with a little 'tug' and flex on the rack you can squeeze the tailgate past it. It's actually the clamps for the bike retaining arms that catch the tailgate. It may be possible to reverse how these are fitted to get the extra couple of cms required.
With an inner bike fitted, and without turning the handlebars, the tailgate can be lifted as far as the handlebars. Whilst not ideal there's plenty of room to duck down under the tailgate and get at the rear of the wagon.
Thule G6 928/9
The tilt mechanism restrains the degree of tilt with a short wire cable. The position of the cable can be changed to allow the rack to tilt further than its default setting. It's a two minute spanner and allen key job.
This allows the rack to tilt almost perpendicular to the ground and allows the tailgate to open and clear the rack and any bikes fitted - without moving the handlebars.
There is plenty of room to stand in front of the rack and access the rear of the wagon.
Just a note to say that the bike is not not on the ground. I think that would be the same with three bikes on - but not sure (yet) about how it's be with the option 4th bike carrier fitted.
I hope the pictures help clarify it. There are other plus and minus points for both racks, but these are just opinions (which I'm always happy to share!!) and have been debated elsewhere. But hopefully this helps others who may, like me, be unsure of how each rack works.
Atera DL3-4
Thule G6 928/9
