Dorset Drifter
I have had my 1992 T4 Westfalia California for about a month now and have only been using it locally for days out. I now want to go further afield but have found a problem with the fridge.
I have read various threads on the forum but can't find an answer, if it has already been discussed please point me in the right direction.
While the engine is running the fridge works ok as switched on and adjusted from the control panel (an internal thermometer has proved this).
With engine off fridge will not run on either leisure batteries or hook up. (Leisure batteries 12.74V and hooked up 14.54V using voltmeter).
Control panel seems to be the problem. It does not show battery voltage or recognise hook up, although the hook up does power the internal sockets and work charger.
With engine off - if I remove the control panel fuse from the bank behind the drivers seat the display goes blank (as you would expect). When I put it back in the display lights up and I can turn on and hear the fridge start. It runs for approx 20 seconds and then stops and the battery icon on the control panel flashes.
Should I check anything else?
If the faulty control panel is stopping the fridge working of leisure batteries or hook up why does it work off the alternator?
Any thoughts/advice would be appreciated.
Thanks again, that will do for today. I think it's time for a beer to celebrate!
